Change speakers to large setting on receiver?
F
FuzzyReets
Hi folks. I have big 15" front speakers and I'm starting to think that maybe I should be setting them to "large" on my receiver. What do you think and what change will doing so make? Thanks.
MidnightSensi
MidnightSensi
Even with extremely large speakers, you keep them set to small. Large is for if you don't use the internal crossover (either don't have a sub, or run L & R out to an external crossover which does the processing for the subs).
So:
If you have a subwoofer connected, select small.
If you don't have a subwoofer connected, select large.
markw
There's several schools of thought on this.
I'm of the opinion that if your mains can handle the lows gracefully, it's safe to run them full-range. I do that with my lowly Athena AS-F1's and so far, it's working out great. Music comes out great, as do movies. Strangely enough, for music, the sub rarely comes into play but when it's need, it's there.
I have the receiver's* crossover set to the lowest it can go (80 Hz) and set it for "main+sub"
*Denon 2802
tom67
Agree with midnightsensi....I couldnt accept the fact either and experimented quite a bit....setting mains to large with a sub produces confused muddy bass....more bass is not better bass....the exception might be someone who likes old classic rock on old CDs with limited dynamic range and just finds a lot of bass noise "nostalgic", because thats what that material sounded like 35 years ago in local dance halls...
avliner
avliner
+ 1 here in the MidnightSensi's school of thought ;)
