Ethan Winer said:
Karl,
I answered that PM just now. I always prefer to answer these questions in the public forums. That way, the effort I put into answering can help others, and you can benefit from the answers of others too. So I'll look for a new post from you about that.
Thanks.
--Ethan
Ok, no problems
. . . sorry
I was going to quickly ask about the products here in this page
Isolation Solutions AU
I am going to try a first attempt at creating some similar Bass traps and sound absorption panels as you have described in your article entitled
“Build a better bass trap”
But down here in Australia, products aren’t or don’t seem as readily available, or at least they are just called different names.
But anyway, I was wanting to do some quick checks, before I go out and buy anything
First, I was hoping to find out if what I was looking at getting was appropriate, and that I will not be getting ripped off.
Basically the two products I was mainly looking at from the site are the:
Noise Control Batts™
Pinkpoly™ Acoustic Batts and Blanket
(there may be others but these two looked ok; to me anyway
I still am at the bottom of the steep learning curve in all this, so I am not sure yet, but what exactly am I looking for in the ‘specs’/product details.
Should I get one product over another?
Which figures are relevant to look at, or are they just bogus numbers to sell the product?
Are these completely the wrong type of things to be looking at to create the sound panels/Bass traps you describe?
And to follow from that, if either of those two products would suit my needs, how does I work with getting the correct thickness and mass?
If I look at the ’Pinkpoly Acoustic Batts and Blanket’, especially comparing the PP2 to the PPSR I see the following:
Name – Nominal Thickness – Mass/Unit Area (gsm) – Nominal Density kg/m
PP2 - 50mm - 350 - 7.0
PP3 - 65mm - 500 - 7.7
PP4 - 75mm - 650 - 8.7
PPSR - 50mm - 1600 - 32.0
Now here, they are both the same thickness, however the mass and density in the PPSR is over 4x as much as PP2.
How does it work in choosing the right product? Why would I (not) get one over the other?
The same goes for the “Noise control Batts” (I won’t copy all the info here)
But looking at the 50mm thick and the 100mm thick ‘sound absorption’ specs:
50mm at 125Hz =
0.2 ‘Sound absorption coefficients’
100mm at 125Hz =
0.3 ‘Sound absorption coefficients’
Firstly, what exactly is ‘sound absorption coefficients’?
And would it be better to use two 50mm batts instead of one 100mm batt? It would still be the same thickness, but how do the numbers work when you multiply them by 2?
I wish to create the three types of panels similar to what you
described, plus create the separate corner bass traps.
Can I just buy the same product and use it in each panel? (i'm assuming so) Just maybe for the bass traps and low frequency range acoustic panels, I can just do two layers instead of one?
Or should I get a specific material for the Highs as opposed to something else for the Mid-highs as opposed to something else for the Lows?
So yeah
. . . basically I am asking if those products are any good to buy, and if so, which one should I prefer and why. Or do I completely drop them and go look for something else?
And within the products themselves, what exactly am I looking for? How should I read those numbers that they give you in the specs, and how do I go about choosing the correct thicknesses and masses and densities? And should I get different product to treat the different frequency ranges?
Sorry if that was a bit to much
But thankyou heaps again,
Kind regards
KJ
