Hey everyone,
Well,I just finished setting up my surround system and am having some issues I was hoping to get resolved
 Before i go to far let me tell you a bit about my set up... The heart of my system is the JVC RX-702B Jensen C-7 Towers Polk T-15 Bookshelves and a Bose VCS-10 Center speaker.
I have a Motorola DVR from Charter and a PS3 both connected Via optical audio into the receiver and they both have HDMI out going to my LG 50" plasma.
Previously my setup was just the reciever and the two floor standing speakers, and honestly, it sounded great, but i needed that surround sound experience. After getting the two rears and center channel hooked up and ready to go, I tested it out... and am extremely disappointed. Let me tell you what i have noticed and done up to this point.
My first issue is with volume. To get the same loudness out of my system as i did with with just the two floor speakers, i need to nearly double my volume setting i used to keep it at. IE Watching TV my reciever volume would be about 11, now i need to turn it up to about 19-20 to hear it properly. This is more an annoyance then anything, as atm I live in an apartment building and cant turn it up to loud anyways...
The more serious issue is my dialogue is HORRIBLE in surround mode. I can barely hear what anyone is saying. As a matter of fact is was so quite that unless i was literally not standing next to it, i couldnt even tell it was on. ( I also have this exact problem with both the rear surrounds. I know they arent made to have an exhorbant amount of sound coming out of them, more for just "extra detail" but i wouldnt think i would need my ear next to them to tell if they were on or not...)  so I turn it up, and yes it becomes easier to hear, however the sound doesnt seem to be clear. From what i understand is the center channel is the single most important speaker of a set up, accounting for 50% of what you really should hear. I would say i hear 80% out of my front speakers, and 10 % from my center and 5% from each of the surrounds
To help alleviate the problem i changed the distance settings on my reciever ( Originally I had each speaker setting set to the actual distance in feet ) to reflect my floor standing speakers being 1 foot away and my center and surround channels at 10 feet away, and then lowering the ?? Db Per Channel ?? of my floors to 0 (middle of the spectrum) and my center and surround to +10 (spectrum max) These two things helped the problem, but movies\tv still sound noticeably better if i use just my front two speakers.
Any ideas on this would help as i am in a few hundred dollars and it sounds worse then when i started
This next one I am sure is just a setting but i dont know what needs to change... If i am watching something that is in surround, my reciever, as it should, automatically switches to surround, and all speakers, well, lets call it for sure get signal going to them. Ideally what i would like is when i am watching something that is not in surround, all of my speakers still get utilized, instead of the center and 2 surrounds turning off. I can easily manually change it to " all channel stereo " it seems a bit tedious to have to switch settings on the receiver whenever i go from a HD channel to a SD channel...
Any ideas guys??? Or am i stuck having to change back and forth...
I know that room shape and speaker location play a major role in sound quality and performance, so i will be uploading pictures showing my speaker layout \ distances etc. I doubt, however, that it would play much more than a minor role in the issues that i am having.
Well i didn't intend on writing such a long post, so apologies up front
 Any and all help \ tips would be greatly appreciated!!!
Sean
