Center Speaker Issue
daveld
I have definitive tech pro cinema 1000 center. My mains are studio monitor 350's. I have been reading about a comparable center speaker to mine. I found that the definitive tech C/L/R 2002 has the same drivers and tweeters. So, would I be able to tell that much difference in sound from the one I own? Or, would it be better to look into getting something different all together?
ReUpRo
The ideal situation would be to use a SM350 for center speaker. It does appear that the LCR 2002 is the matching center. IMO, try it and if you don't hear the benefit, return it.
