Center or Bookshelf Questions
Daryl42
Daryl42
I am considering building a setup using the SVS Prime offerings.
But I am also considering using the bookshelf as the center channel. I am pretty close to the TV, and any guests will be fairly off axis. Aside from that, it has a small midrange driver and not as good reviews as the towers.
Question:
The towers and the center both have tweeters that start at 2.1 kHz. The bookshelf has a tweeter that starts at 2.3 khz. Is this a problem?
What are the most important differences to look for when trying to match it with the towers? Both have the same response, despite the bookshelf lacking two woofers.
Thank you.
Center:
http://www.svsound.com/products/prime-center
Bookshelf:
http://www.svsound.com/products/prime-bookshelf
