Center Channel Stand
W
wyatth
I currently have my center channel (Definitive CLR2500) below my Mistu 62" DLP. I have Bello meida stand and it fit right beneath everything. However, because of the (useless) speakers on the Mistu, the screen is high and to me the sound is coming from too far below the image. I think, I would like to buy a stand that would go behind the tv and support the center just above the screen. I've seen the sanus stand that supposedly allows your center to rest on top of the TX, but I don't like the looks of it at all. The CLR 2500 http://www.definitivetech.com/loudspeakers/clr/clr.html#2500
has a built-in sub and would probably weigh too much. BTW: for you purists, the idea of a center with a built-in sub sounded stupid to me also, until I heard it. Then "I be hooked".
Thanks,
- wyatt
