Center channel speaker
pepr37
Can a center channel speaker be used along with a A/V receiver right and left channel stereo speaker hook up?
Pepr37
just-some-guy
just-some-guy
what ? are you asking if a speaker intended as a center, be used as a right/left ?
sure it can. but it may not be designed to be used that way.
It kind of makes no difference from the standpoint that a speaker is a speaker. What just-some-guy may be getting at is that some centers are designed for a horizontal placement and it may have issues being stood up on end. Some, like mine, are identical so it is intended to be used as a center or main and I use another pair as surrounds as well.
If you mean can you hook both left and right channels to a single speaker, the answer is no.
