Due to layout constraints (the center of my pull-down projector screen is in front of a door to my garage), I plan to mount my center channel above the projection screen, which will put it about 7 feet off the ground. I evaluated the possibility of a floor stand, but I will have to move it out of the way on a regular basis to get access to the door, which is obviously not a very desirable situation. I obviously need to angle the speaker toward the listening position, which is 14 feet away and will allow me to have a relatively shallow tilt angle (from horizontal). I plan to use a TV wall mount for the speaker since it is somewhat heavy and since nobody appears to make a suitable wall mount specifically designed for a center channel speaker. Has anyone else had this issue, and if so, what was your solution? BTW, am aware of the non-optimum position of the center speaker relative to the mains, but I want to at least try this option in hopes I can avoid the floor solution and its inherent problems. TIA
