Center Channel Recommendation - under $400
Phaze
Hi all. I'm looking for a channel speaker recomendation to use in my home theater setup that will compliment my existing Paradigm Studio 100 V.2 front speakers and Paradigm Studio 20 V.2 rear speakers. I will be driving all the speakers with a 125 watt per channel (at 8 ohms) multi-channel amp. Since the Paradigm's are 8 ohm speakers should the center channel be too? Looking to spend about $400. Thanks for your thoughts and suggestions.
mazersteven
mazersteven
You need to stick with a Paradigm Studio center. Even if you have to save to increase your budget. :D
ParadigmDawg
ParadigmDawg
there are a couple of Paradigm Reference Studio/CC v2's on Ebay; I am not sure you will find a new one.
