Center Channel Recomendations...
Bobby2x
I am looking for a new center channel speaker, I am currently using a outdoor rock speaker placed to the left of the TV set.
My receiver is Sony, and outputs 100W a channel.
The TRICKY part is that I dont have much room to work with.
It's a LCD screen and there is only about 5 inches of space below the screen on the stand.
I was thinking abut mounting it to the wall behind, but worried about the TV blocking the sound, Any thoughts, or recommendations on a "Thin" center channel? Looking to spend about $150-250 on the new addition.
claudermilk
What are the rest of your speakers? Everyone here will tell you to stick with the same line if you can.
With that in mind, there are a number of options made just for use with the flat screen TVs & wall mounting, though I would think behind the screen is a bad idea for the reason you mention.
Tex-amp
Here's a link to a solution I saw on another board. They used a wall mount TV stand to put the enter channel above TV.
