Center channel question
samalama
I am shopping speakers. Looking at Sonus Faber Concertina fronts. I have limited space for center channel speaker (spousal furniture limitations...). Have only been able to locate the Bose center channel that is thin / short enough for the space. Two questions:
Any concern matching the Bose center with Sonus Faber or other high quality fronts?
Any other suggestions for a center channel speaker less than 5 - 6 inches tall?
s2pdname
There have been many discussions on this site (and others) regarding the timbre matching of the front three speakers. I searched "timbre match" and came up with about 34 threads where this has been discussed. Basically, you want all three of the front speakers (L,C,R) to be matched acoustically. This is so that when the panning of a sound, a car / airplane / etc., travels from one side of your room to the other the sounds flow evenly from speaker to speaker. Usually timbre matching the front 3 speakers means that they should at least come from the same manufacturer.
I would say that if you absolutely cannot place the center anywhere else (possibly on a bracket extending from the wall), then you should look for a center speaker that meets your needs and then get the fronts that match that particular center.
samalama
thanks. i'll do the "timbre matching" search and see what else i can learn...
samalama
How about suggestions for a thin / short center channel?
Shinerman
Shinerman
Sonus Faber and Bose together? Um.......... NOOOOOO! Please..... No!
Timbre matching in highly recc. for the front three speakers. However, if you can't, then you must find a close match. I can't see how Bose would be even close in any aspect.
Maybe a inwall center?
Shinerman
Tomorrow
Tomorrow
Watch for similar crossover points in multi-driver speakers...even from the same manufacturer...in your center and mains.
Good luck in your search.
Shinerman
Shinerman
Seems like Polk made some pretty short center channels. Not sure if these would match up well though. Also, seems like Definitive Technology also had some short centers.
Shinerman
samalama
Definitive Tech looks promising. Will check them out.
