TLS, as do some of the most fanatical of experts, will not accept a horiz MTM. However, others believe the compromise is over exaggerated and often. Basically, if you are dead straight and center, you're pretty good to go with anything that is not horribly designed. It's when you start approaching about 20 degrees or so that you might have some very bad issues, at least in my impressions. A better horiz MTM will have closer driver spacing, and lower xover point . . . but that entails other compomises too (because best dialogue intelligibility usually would mean a higher xover point, respectively, like 2k-4k).
The 3way BW centers that TLS mentioned are called WTMW, and the benefit of having that dedicated single MIDrange driver is that now the redundant side by side woofers can be crossed low enough where the comb filtering is not offensive to our ears.
The bookshelf for a center is a good idea, as long as it can be vertical (upside down is fine, but NOT sideways unless you really know that the driver spacing, speaker design, and all that will be fine), but the compromise now is that you have one driver instead of two, for less SPL capability for the oft demanding center channel.
Hmm. So what I'm reading here is... it's all subjective and really up to me to figure out what I like? I get that part.
If I had old bookshelf speakers, I'd probably just drop one of those, mounted vertically and see how it compares to the Motion 8. I upgraded from satellites, and after getting a proper setup those speakers are long, long gone and I'm trying to forget they ever existed.
All I know, despite seemingly well designed, the Motion 8, no matter the positioning, just can't compare with the rest of my system. I want an even sound stage between the fronts and I just can't seem to pull it off w/ the Motion 8s. I also know that, for whatever reason, the HTM-61 just sounded off in listening tests. I still want to try it out again and see if the sales people will let me angle it up/down to point it towards the listening area and see how it performs.
The problem with the B&Ws TLS mentions... I can't afford those as discussed. Wish I could.
I am curious, are you enamored with the 683s?
I'd say yes.
When I did my audition, I picked a few speakers I'd like to audition based on similar specs/pricing and tried to find local places (Magnolia in Best Buy and a local Hi-Fi shop). I tried the Motion 10s and 12s from Martin Logan. I tried a Mirage OS³. Two Def Tech models. The B&W 684s and the 685s. I also tried some of the B&W CMs, which I absolutely loved but one speaker was pretty much my entire BUDGET for front speakers. For fun I also tried the non-powered electrostat from ML, which sounded amazing... so long as you sat in that pinpoint center sweet spot. Loved the sound, but I knew I'd never sit in a single position in the room and it was especially ill suited to HT if I ever wanted others to be able to enjoy my setup!
I also auditioned I believe 3 different Klipsch setups (might have been an Energy in there). I liked them, but it didn't give me the same "wow" that the 683s did for the price. I recall going from the Motion 12s, which had the same MSRP, and feeling like the 683s were like pulling a blanket off the Motion 12s with the level of clarity they offered.
So yeah, I'd say I am enamoured with the 683s. They were, without question for me, the absolute best speaker for me at that price range. I'd love the Diamonds (or a pair of Nautilus!), but that's a pipe dream unless I win the lottery.
The Audyssey mic is actually more accurate than the ubiquitous Radio Shack meter, but the former won't give you a reading! If you ask professionals in the industry, some do balk at the RS meter and its deficiencies, but it's basically what 99% of what us enthusiasts own, and I am no exception. The analog one that is.
I'll probably head out to RS and pick one up then. Website indicates they don't have them in stock on-line, but the local RS has it in stock supposedly. We shall see.
Definitely angle the speaker, no matter what you get. Look at different Auralex products like Mopads if its sitting on resonant wood furniture (kill two birds with the one stone). Otherwise, many people use doorstops too.
I'd probably just go with TLS' recommendation. I recently built a kit subwoofer, and that was all it took to convince me of the DIY aspect. I've built a DIY PJ screen since, and any future speaker upgrades will at least be a kit, if not full blown DIY. Good luck!
The Auralex products will be difficult for me to obtain, given the closest place that sells them seems to be in Philly, which is ~60 mins from the house and not somewhere I go often. I'll keep it in mind though, for sure as looking at their website that would be good for the center channel, no matter what I end up with.
DIY opens up a whole different aspect to the hobby (or lifestyle) of home theater and is something I'm definitely keeping in mind when I figure out what I want to do.
Thanks for all the help!
