Paradigm on-wall
I think they offer on-wall and in-wall versions of the paradigm monitor series speakers. Check your local dealer to see if one of these will work for your application. With the same drivers and tweeters, it should offer the best tonal match with the mains.
If your center channel is going to be a compromise, you might as well keep the current one unless you are having problems with dialogue on movies.
