Have you calibrated the levels of your speakers?
Next, look at acoustical issues. If the speaker in on a shelf, make sure it's far enough forward that it hangs off slightly. Also, make sure the speaker is angled towards the listening position. If you have a laser pointer, you can lay it on top of the speaker and see if the red dot lines up to ear level at the seating position.
Lastly, consider acoustical treatments for first reflections from the front three speakers. (L,C,R) Early reflections are sound waves that are bounced off side walls, ceiling, and floor from initial speaker output. They arrive at the ear just milliseconds away from the original signal and can make speech very hard to decipher. I've treated a couple of rooms with this problem and it makes it a lot better.
