Spenser
Hey all, looking for suggestions for ceiling speakers to be used for surrond in a small room. Anyone have any ideas?
Spenser said:Hey all, looking for suggestions for ceiling speakers to be used for surrond in a small room. Anyone have any ideas?
Spenser said:yeah, I can easily wall mount the speakers. What do you have in mind.
.....Spenser, exactly what are the measurements of your room?.....Spenser said:Hey all, looking for suggestions for ceiling speakers to be used for surrond in a small room. Anyone have any ideas?
.....Spenser, there's nothing wrong with a 10 X 12 room unless all surfaces are concrete, of which you'll BRIGHT in your pants....even then, classy looking rugs on the wall would tame that....I don't know, I've thought about this one a bunch....and, after trying to visualize your room with the couch against the back wall, I would go with wall-mounted surrounds in the back corners aimed about a third of the way down the opposite wall from the rear wall, just high enough to not crack a head while sitting on the couch....just like any other system setup with surrounds, you'll have a sweet spot in the middle of the couch unless you set the system to be left or right of the middle of the couch....you said you "love" the Atlantic Tech 2200SR's which AVRat just said could be wall-mounted for surrounds....you might consider moving the whole system from the living room to your dedicated home theater room....unless of course your wife says over her dead body....one more suggestion....move that couch at least a foot forward away from the back wall for the surrounds to be a bit behind you....now it's your call on all this worthless drivel/gruel I've spewed....good luck, and congratulations on a dedicated home theater room....sure beats a living room with openings to kitchens and hallways and such....as far as room issues being tamed, you're probably better off with 10 X 12 over a larger room......Spenser said:The room is in the basement. The viewing area is about 10X12...not that big. I just got the Sony 50 inch sxrd. I plan on buying the Denon 2307ci when released along with the Denon 1907 dvd player.
