Surround speakers
Remember, the surround channels in a 5.1 system should go on the sides of the listening position. If there is no room on the side walls for bookshelf speakers, then consider inwalls with an aimable enclosure or aimable tweeter so they can be pointed towards the listening position.
The speakercraft AIM series, for example, allows you to aim the whole speaker.
