Hello,
I’m fortunate enough to be able to run speaker wire behind my walls prior to drywall installation. I ran some speaker wire along my ceiling and where I want to place a ceiling speaker will be almost directly underneath some CPVC piping (see photo).
I’m concerned the speaker’s vibrations may cause future damage to the water pipe fittings and cause a leak. Is there much vibration from the speaker on the top side (part that’s in the ceiling)? Should I move my speaker location over? I measured my ceiling speakers to run parallel with my front speakers but is this necessary?
The unfortunate part is my drywall will be going up tomorrow so I would need to do adjustments by tonight.
Thanks for the help!
