shokhead
shokhead
How low can each disc play a recorded sound? Lower Hz?
I have read that Tom Nousaine has measured 5Hz on the Telarc 1812 CD:D
There used to be an online site with lowest frequency on some Cds but now I cannot find it, or the name escapes me.
shokhead
shokhead
Wow!
Didnt think 5Hz was possible on a reg cd.
skizzerflake
skizzerflake
I don't think it is, but I'm not sure about a SACD. Unless you have some sort of super-woofer, you couldn't do anything with a 5 hz signal anyway. You couldn't hear it either although if it were loud enough, you could feel it. If you don't have enough woofer, all you would get from 5 hz is a big power surge that might clip your amp without delivering anything audible. If your woofer could reproduce it, 5 hz would also make it sound really weird due to severe doppler effect distortion. It would add a disturbing quaver to frequencies above that subsonic note. You probably need a cannon simlar to the ones used for the 1812 Overture.
nav
nav
I can't think of any reason a CD would not be able to store a low-frequency tone of any sort except for storage limitations (a storage limit of one second makes 1 Hz or less unrealistic; a standard CD can hold 4440 seconds). High frequencies are another matter entirely.
Use an audio editing program (such as Audacity, for a free option) to generate a 5 Hz (or lower) tone, save it to a WAV file, and burn it to a CD. Rip the CD to WAV and open it again in Audacity. If the sine wave remains intact: your CD just reproduced that signal.
Whether or not your listening system can reproduce the data on the CD is another matter (please take care if you try this; sine waves at any frequency, especially at full amplitude, can be less than healthy for your equipment).
Well, some do have super subs:D A few have been pictured at this site. Tom Nousaine has 4 or 8 18" subs in an infinite baffle arrangement. :eek:
Just recently someone posted a link where a 16Hz wave was making a carpet float.
Yes, it is all sensory, not auditory.
shokhead
shokhead
limited
I just thought a cd was limited as compared to a DVD-A/SACD.
racquetman
racquetman
I just found this info. Don't know if it's correct or not.
"The human-ear cannot hear DC or very low frequencies. Most CD players will not reproduce any frequencies below 10 Hz and hence we have freedom to add or remove low-frequency waveforms. Such addition and removal will greatly alter the peak excursion of the master. This form of processing will also compensate for any DC offset present in the pre-masters."
from: http://koo.corpus.cam.ac.uk/mixerton/whitepapers/mastering/mastering.html
no. 5
no. 5
agan, not shure if this is right, but, I would think that recievers input and output freqency response would be enough to 'not leave any sounds behind' as it were, so I looked up a Yamaha and a Denon, both had a CD input FR of 10Hz to 100kHz.
shokhead
shokhead
I mean what each disc is capable of,not what the equipment will let them do.
