I'm not sure if this the place to ask this but here goes.
I've been doing a lot of reading about how speakers should sound and how you should demo speakers with a cd or two of your own you are familiar with. This makes sense to a point, you want your speakers to sound good to you with the music you like to listen to, but that boils down to personal taste and not necessarily accurate speakers.
Accurate speakers should be able to replicate music that sounds as close to the original source as possible. The original source being the artists and their instruments, the problem is that there is a cd between the original source and your equipment, and these cds are all different. I have 7 or 8 cds of a duo called Acoustic Alchemy ( great guitarists I might add ) and no two recordings are the same, some have more high end than others, some more bass, the point is thay are all different. It's not possible for me to judge weather a speaker is accurate or not if I don't know what one of the 7 or 8 cds that I have is accurate, or any other cd I have for that matter.
Sorry I know I've rambled too much
Anyway, could anyone tell me if there are any recordings out there that are considered extremly accurate and I could use to judge the quality of any speaker I might choose to demo?????
thanks,
Frank
