<font color='#000000'>I have successfully used windex - and you can scrub a bit harder with a cloth or paper towel. Be sure to scrub in a direction that is outward from the center (not along the rotational path) and you should be OK, even if you accidentally create a scratch.
CDs are more forgiving then people think, and you can abuse them quite a bit before the error correction can't handle it.</font>
