Carver AV705X For Sale!
Seth=L
Seth=L
Up for sale here is one Carver AV-705X 5 channel power amplifier.
Specs: 125 watts per channel 20hz-20khz @ 8ohms all channels driven (power steering allows more than 125 watts to go to any channel/channels that are requesting more power) THX Certified, LEDs to drain capacitors (no loud pops when shutting the amplifier off) Two 25,000 microfarad capacitors from Philips, Class H power design.
Some notes. This is for the amplifier only, no manual or rack handles. Each channel has independent level controls and one of the knobs is broken. You can use a 5/64" hex-bit to adjust the channel if you need to do so. The channels are all set too max already, so it is unlikely this would affect the user (THX standard says this is optimum).
Pictured at the bottom-
Make me an offer......:)
Seth=L
