they are the exact woofers that i have. DVC woofers. what would be the major difference between the enclosure that they are in compared to what would be built for home? the box is 1" mdf and the enclosure is .5 cu. ft. for each sub. sealed which is what the manufacture recommended, and the only thing that i can think of that makes it a car enclosure is that it is carpeted? and they fire downward which seems to be more common in home audio than car audio. I am just curious because if i need another box built i will just buy another single sub and make one for it, the enclosure cost me $850 that they are in now and i would hate to have to remove them from that box, Oh and that $ was without the subs just the box. oh yea what amp would you recommend using?
thanks,
chuck
