Car components for bookshelfs...
diceman1000
so,i have a set of CDT CL61 mids and aset od SEAS aluminum neo tweeters that i recently pulled from my car. i've been contemplating gettin a set of bookshelfs to replace my front speakers and thought that i may be able to use these in conjunction with a 4 or 2 ohm dummy resistor to make a set of bookshelf... what do ou guys think?
these are the mids
1 pr 6.5” mid-woofer
Frequency response 55Hz-5.000Hz
Power handling: 80watt (110Watt Pk)
Impedance 4 Ohm Sensitivity: 91.7dB
Mounting depth: 2.75”
Cut out diameter: 5.75”
Cast frame: OD 6.7
Cone: Reinforced carbon paper cone
Magnet weight 20 Oz
Cone surround Buytal rubber
Impedance: 4Ohm
Voice coil: 1.0” (26mm)
Fs: 70Hz
and these are the tweeters
my biggest question is, will these make a better bookshelf than what i can buy for $50 to $150
Sent from my SCH-R760X using Xparent Skyblue Tapatalk 2
diceman1000
Crap, I just noticed that the pictures didn't copy over, I'll post pictures when I'm on the computer...
