dannv said:
Ill start off by saying that i am on a college budget. 1st i was wondering if there is a way to hook up car audio equiptment in a houseing situation. second it apears to me that home audio is underpowered compared to car audio i see 2000 watt subs for cars at under 200$ and yet my 200$ polk psw10 cost me 200$ and only has 100 watt power. do hte 2 utilize power differently? my last question is if i am looking for a cheap audio system with extreme bass and good everything else how does home audio compare to car audio?
Other than using 4 ohm subwoofers to build an HT subwoofer with a plate amp, I'd shy away from using car head units and amps to power home audio speakers. Different volts for different folks.
Many car subwoofer drivers ranging from $150 to $200 are very inefficient, and require huge amplifiers. You take a 2 ohm dual voice coil sub, and parallel it in a car, and it's going to require a 1 ohm stable amp with a nice sized capacitor to avoid killing your alternator. Big bucks.
You need to look at the car subwoofer drivers' rms rating, and not peak rating to determine more accurate power handling. Most HT subs list rms power handling. That's not to say that HT subs don't use inferior drivers - many do. But most HT subs utilize 4 ohm single voice coil subs, the same subs used in car audio applications (minus dual voice coils for the most part).
Your 100 watt amp on your Polk PSW10 will do wonders in your car. That amp is rated at low distortion levels. Consider the amps size compared to that of a $150 car amp.
You won't get extreme bass in a dorm/house on a budget compared to a car. Think of the volume in the car versus a dorm room/bedroom. It takes multitudes of pressure from a HT sub to pressurize a room the same as in a small volume of space such as a car.
$400 towards a car system (subs, amp, box and wiring) which can ruin your hearing won't even touch a system needed to do that in a dorm/bedroom/familyroom.
My guess is you'd need over $4000 in HT subwoofers to even come close the to dB's of the car system. You would need a pair of these due to the difference in spacial volume:
http://www.svsound.com/products-sub-box-plus2.cfm
Compared to this (dirt cheap hearing loss):
2 of these:
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10586041&CATID=1016&SPOTID=3
powered by one of these:
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=601520567
I'm not saying they'd sound the same, but for pure bassheads, stick with the car to impress the friends.
