I have always known the myth of super-sized speaker cables, but wonder if there is a difference in the power cables for a car audio amp. I was at an electronics store and the salesman was recommending a 4 gauge power cable because I was running it 20 ft to a 500watt amp. Before I plunk down $80 on a power line I wanted to be sure I was not being fed a myth. Hell, if you need 4ga to go 20ft how the hell am I getting power to my house over those dinky little wires the utilities company uses??
Is there really a legit need for this beefy cable or will a 10 Ga be sufficient to get power from my mustang battery to the trunk where the amp and subwoofer will be installed?
Isn't the fuse the more important aspect of this line? I have noticed that most kits I find are higher wattage rated, wouldn't this be a bad thing for me (in other words the fuse on that 1000watt kit won't protect my poor little 500watt amp from a surge of 700watt juice)?
Thanks in advance for your help!
