Hey
Today i tried to install my 2500W max subwoofer, has the amplifier with it already installed and was previously used by a good friend of mine, worked perfectly with no problems. Today when i installed it to my car i ran into a problem where the amplifier wont start, i am more than sure that i connected the wiring properly, the electricity gets to the amp and the grounding is also well done. Tested with a tester so it probably wont lie. Also showed it to my friend who owned the subwoofer before. He also told me that everything should be working perfectly but apparently it isnt. He thought that the problem might be with the remote wire running to the amp. The radio i am using is pioneer one, with subwoofer control and really similar to my friends who owned the subwoofer. He told me to buy this one. So from behind the pioneer radio, the remote is wired blue if i am correct. it has a split, one of those i connected to my remote wire which runs into amp. the other goes to the car stuff. The car i have is ford focus 2003 with universal body. How can i control and find the problem i ran into? Since im not 100% sure it is about the remote wire but should be since when i turn on the ignition and even start the car it still wont turn on the amp. Thanks for reading
I really do appreciate it
