Canton Karat Reference 2 DC
steve
<font color='#000000'>We have completed our Canton Karat Reference 2 DC review and are ready for discussion. &nbsp;In the next few weeks, we will update this article to include our own measurements. &nbsp;So stay tuned and lets start the discussion.
Canton Karat Reference 2 DC Loudspeaker Review</font>
petermwilson
<font color='#000000'>Hi Steve,
I was wondering if the Canton's could have been driven by the Denon 5803 given their ohm and sensitivity spec.
Peter m.</font>
steve
<font color='#000000'>The Denon should have no problem running the Canton's as it has a great amplification section.  If you want a bit extra boost, you can bi-amp the multiroom channel to the front.  Whith combined amplifiers, the Denon will definately be more than enough to run these speakers.
This subject was discussed in Gene's review of the Denon where he outlines exactly how to do it.  Check out the following link.
Denon 5803 Review - Page 4</font>
gene
gene
Audioholics Master Chief
Administrator
<font color='#000000'>Peter;
Using a receivers internal amps with an amp section any less than a flagship product such as those from Denon, B&amp;K, Yamaha, etc is not advised given the low sensitivity and reactive load impedance these speakers present. &nbsp;I would strongly caution potential buyers to mate these speakers with a high quality, low impedance dedicated amplifier. &nbsp;I should be able to put up some impedance plots of those speakers in a few weeks when my equipment returns from calibration.</font>
