Anglofun
Afternoon
I have an Epson 2350 projector, with a Yamaha aventage a4a on an appletv 4k.
For the life of me, I can't get the the 4K HDR setting to happen. No matter what it goes back to SDR. An idea (of stupidity) was my HDMI cable. So I bought a 48GPS HDMI hoping it was that, but it wasn't.
Hoping for an easy fix!
BoredSysAdmin
BoredSysAdmin
what is the source app you're testing hdr with?
dolynick
An AppleTV 4k box can certainly be set to output HDR full time or auto-switch with content.
If it is failing the test, I would look at settings for HDMI on the other two devices. Most likely it will be on the Yamaha and be a setting that enables higher bandwidth on the port(s) outgoing and incoming. It would be worthwhile to also check the Epson though just to be sure there isn't a mode setting there as well.
Edit:
A quick search suggests your Yamaha should be set to "mode 2" for that HDMI input (60 Hz 4k HDR w/ dolby vision suport). Mode 3 is required if you want 8k or greater than 60Hz on 4k.
A little more searching suggests that your Epson is limited to 18Gbps and only supports 4k HDR @ 24Hz (or maybe 30). Try setting the AppleTV output to that and see if you have more luck.
Trebdp83
As @dolynick mentioned, the projector does not support HDR @60Hz. If you want everything output in HDR from the Apple TV 4K, you can set it to 4K HDR @30Hz. If not, you can set it to SDR @60Hz and turn ON Match Dynamic Range and Frame Rate and anything in HDR @24Hz should work. The projector's limitations indicate a High Speed(10Gbps) HDMI port rather than a Premium(18Gbps) HDMI port which would support HDR @60Hz.
Anglofun
Wow. that makes perfect sense. Can't wait to try. Will chime in with results
