Can't get DTS to display on receiver
K
karenf
we have a Sony HD lcd tv, HD satelite receiver, Sony DE 898 receiver,
receiver has DTS decoding availability,,,Sony dvd with DTS,,,,we have a digital optical output jack on back of DVD,,,BUT on back of Sony 898 receiver, the digital optical iinput jacks (4),,,,TV/Sat, MD Tape In, MD Tape out, and last one is CD Sad Cd,,,,then there are 2 digital co axial in jacks, one of them says DVD,,,,but I don't have a digital optical in jack for DVD so where do i plug my digital optical audio cable in,,,,,I have it coming out of the digital optical audio on back of DVD player,,,but like I said, no digital optical audio in for DVD player on back of new Sony DE 898,,,,we were told by kid in store where we bought receiver to plug into the TV/Sat digital in on receiver, but we get no DTS, we were playing Gangs of New York which lists DTS as a format on dvd, thanks in advance:confused:
jcPanny
jcPanny
Digital audio
To get digital audio you will need a digital coax or optical cable from the DVD to receiver. Either will work fine. It sounds like your receivers default (and lable) are for the coax cable. No problem, all you need to do is use the receivers setup menus to identify the correct audio input to use for DVDs (i.e. optical #1, etc.) once this is complete, you should have no problem playing Dolby OR DTS 5.1 channel sound from DVDs.
Right now, your receiver is probably getting audio from the DVD via red and white analog audio jacks and using a mode like dolby pro logic to play the 2 channel sound track on 5 or more speakers.
philh
Sony receiver defaults to coax input over optical for DVD, but that is changeable. My biggest complaint with the sony receiver is getting it set up correctly, the manual is crap. Take the easy way out and just use coax cable between the player and receiver. Spend your time figuring out the DVD player settings and receiver settings, which MUST be changed to get the system to work properly. Make sure the DVD is putting out digital signal, and turn the DTS setting to on. Make sure the reciever is set to accept the digital signal and properly handle it. When it is finally set correctly, you'll ask why will I ever spend money at a movie theater again :) ?
JVC
JVC
Most dvd players ship from factory, with the DTS turned off. Go into the dvd player's setup menus and make sure the audio output is set to "Bitstream", instead of PCM.
Your manual should walk you through re-assigning the digital inputs. Not hard to do.
Good luck!
philh
Good luck!
Sony manual is difficult at best. I read a friend's Onkyo manual to get my Sony receiver set correctly!
