Hard to say, what with sound being a personal preference..
Actually, for softer music, I'd have to say none of the above but that's where preference comes in. Of course, if you don't compare and simply settle for something sound unheard, you will most likely be satisfied, at least until you hear something you find you like more.
but, I will suggest that the front mains be of the same manufacturer/line as the center.
One more suggestion. if you DO make time to listen before purchasing, make your decision based on music you're familiar with rathet than a movie soundtrack. When you find a musically satisfying system, HT will also please. IT doesn't always work the other way around.
