Cant Connect my Subwoofer
V
vectormyke
Hi,
Thanks for welcoming me into your fold, very grateful.
I bought this LG subwoofer for my LG home theater but I discovered that the Subwoofer output on my home theater has no audio output. Please how can I connect my subwoofer to the home theater since the sub output is dead.
Thanks
Welcome to Audioholics!
Check to see that your speakers are set to "Small". If they are set to "Large" then the audio which would normally go to the subwoofer would be re-routed to the speakers instead. Also check to make sure the sub out is turned on or set to 'Yes'. The result of missing either of these settings would be a sub out that didn't do much of anything.
Pwner_2130
Pwner_2130
Also make sure that your LG is indeed a powered amp and that it is turned on otherwise no output for u
Seth=L
Seth=L
Please describe the subwoofer's connections. Does it plug in a the outlet, or just speaker wire? What is the model # of the LG components?
