bryantm3 said:
are you sure the VOB files are interlaced??
i thought they went frame by frame, and the dvd players converted this info to make it interlaced.
Nope, they're interlaced. I've ripped files off of DVDs before, to get live animation reference when working on something in LightWave, and I always have to reverse the 3:2 pulldown to end up with the original 24p video. The actual VOB/MPEG-2 file is 30i. For NTSC, anyway.. PAL is 25p.
If the video is deinterlaced properly, you don't lose anything.. the full frames are all there, it's just that some of them are split over two frames of animation. If the fields are simply combined (rather than discarded, which most deinterlacing software does), you end up with the original full-resolution frame. In a video editor, you have to be a real stickler about recombining the fields in order to do it right. I'm not sure how DVD players or TVs do it.
We won't have to worry about that with the hi-def DVDs, though. Both BD and HD-DVD are encoded on the disc at 24p. Assuming that's the framerate of the original footage, of course. But most everything is shot at 24fps these days, including almost all pre-recorded TV shows. I think reality shows still use 30fps video, but that's not real TV, so it doesn't count.
