Can you recommend a thin white passive sound bar?
ChuckvB
Okay, this is an alternative to the post below for an active soundbar that works with a receiver, in case that's a no-go. Can someone suggest a thinner as it sits on the mantel passive soundbar in white that sounds good just for Center, right, and left for a larger room?
ChuckvB
I'm going to go a different direction I've come to realize that a sound bar on this setup will just sound like one speaker given the distance backed sit and size of room. I need to get more separation between the right and left I'm going to put a thread together looking for three separate speakers that I can use with at least the right and left being is hidden as possible or if I have to freestanding traditional. I'm going to start a different thread.
KenM10759
KenM10759
The KEF HTS80003 passive soundbar is closest to having separate speakers, but even 12 feet away it's just not the same as separate speakers. If I was more like 6 feet, it would work fabulously.
I have wall mounted KEF T101's as surrounds and they work extremely well. I'm thinking about going to wall-mounted T301's for the front three, though it's really just a case of 'if I come across some for cheap' when I happen to have money in my pocket. Very low priority.
ChuckvB
I've come to the same conclusion. At the distance back we sit a sound bar would just sound like one central source. I'm going to go with three separate speakers and I've opened a thread for non obtrusive speaker ideas.
