Can this be fixed? How do I find someone to do that?
F
Freedom
Onkyo HT-S3300 - this is a 2010 model
The remote no longer works.
Replaced batteries, nothing.
Went on ebay, bought a new one, specific to this model, NOT a universal. Still nothing.
So I'm thinking the problem is the receiving part, on the unit itself. Now what?
Thanks in advance. I am in Rhode Island, no clue what to do. Do I have to buy a new one?
markw
Your best bet is to contact Onkyo directly.
slipperybidness
slipperybidness
Good advice.
Personally, I would do a factory hard-reset and see if that fixes it. That's probably the first thing Onkyo C/S is gonna tell you too.
You will lose all settings and it will go to factory default, so you may need to spend some time with a pen and pad to copy settings and connections, etc.
