Can someone help identify these "Polks?"
RickH
Picked these up at S.A. for ten dollars...they sound pretty good actually.
There are a lot of similar Polks in the Orion book but I can't seem to find these.
6 1/2" woofer marked "SDA CRS" Date on woofer is Aug. 1985. Rectangular dome tweeter marked "SL 2000"
Ported box measuring 8 1/2" deep 9" wide 17" high. 5 way binding posts
with serial # 5JR08858. They are fused externally..Oh, and the port is located
1" directly below the woofer and has an i.d. of aprox. 7/8". Vinyl wrap.
Thanks in advance....if you have these...let me know if you like them.
Rickster71
Rickster71
This thread my help you out:
http://www.polkaudio.com/forums/showthread.php?t=25377&highlight=identifying+vintage+tweeters
SDAs are pretty well sought after, so I think $10 is probably a deal for them. SDAs are probably some of the best speakers Polk did, but you also need the cable for them to get the SDA effect to work.
The best way to find out what they are would be to ask on Club Polk, which may have been what Rickster was getting at.
