I recently replaced my Yamaha RXV1500 with a Marantz SR5003 because the 1500 was randomly refusing to start up. It goes into protection mode within a few seconds of powering up. If you leave it for a few hours it usually works again, but occasionally it takes a couple days so it got moved into the bedroom and the Marantz took its spot in the rack. Today, after less than 3 months of use, the shiny new Marantz did the same thing.
I have been trying to figure out if there is something in my system that could be causing the same failure. To start, my HT is set up like this: all source audio and video from my PVR, DVD player, Computer, and game systems go through the AVR and a single video out goes to my TV via HDMI. As for audio out, the AVR only powers my surrounds and center channel, the front signals are output to an Anthem PVA2 which powers the front speakers. The sub channel is split and output to a Yamaha RXV550, which powers a custom built dual 10" sub enclosure. (I realize the 550 is a poor choice to power subs but it works quite well and so I wait for a good deal on another dedicated amp to come my way).
Everything I can find relating to this issue is related to the power circuits so my troubleshooting started here. Since the Yamaha started to fail, I have moved to a new house, so the house wiring can't be the issue. I have tried replacing the power cable, tried removing the power conditioner, tried multiple circuits in the new house with no success. Next I looked at my source inputs. I have upgraded (where possible) to HDMI cables from optical and components, with the exception of my DVD player which does not have HDMI output. This is one common item to both failures but I am unsure how my DVD unit could cause it. Next I checked my outputs and speaker wiring. I have replaced my TV since the Yamaha started to fail, as well as upgrading the output to the TV to HDMI so that is out. All speakers and wiring are all the same but since I have moved, everything has been reconnected and double checked. The speakers and wiring worked flawlessly with my backup receiver (Yamaha RXV550) for more than 2 months between the 1500 and the 5003.
It should be noted that although the RXV1500 gets used very rarely in the bedroom (maybe a dozen times), it has never failed to work since removing it from the main system. However, there were stretches of 1-2 months in the main system where it was also fine before I got sick of wondering if it would work on any given day and replaced it.
Does anyone have any insight on this issue before I ship it off for service? Is there anything that is known to cause this issue? Anything you can spot in my setup? Or is this just my luck? At least this one is still under warranty...
Sorry for the long post, just trying not to leave anything out.
