Can Metra SW712-250 speaker cable be used for in-wall wiring?
rma123
Hi: I am thinking of buying this cable for in-wall wiring for my home theatre. Does anybody know if this can be used for in-wall wiring? I donot see CL2 anywhere in the specs.
Thanks
Ravi
ParadigmDawg
ParadigmDawg
If it is CL rated then it will say that. Run to Home Depot and get their CL-3 wire. You can get 500ft for 80 bucks.
MDS
CL2 or higher is required for in-wall wiring to be code compliant. So CL3 or CM is also acceptable.
