Can I use My Marantz 1070 as a Preamp with my Marantz SR6200??? Please help!
G
Gtmcmillanjr
I just got my dad's old Marantz 1070 out of the shop and got it restored completely. In the meantime I found a great deal on a Marantz Sr 6200 Av Reciever .Can I use the 1070 as a preamp and integrate it in with my home theater system for my music? I've never run two amps before and I'm not really sure how to do it. I'd really like to use this amp in my setup since it holds sentimental value for my late pops. Any help would be much appreciated.
My setup as of now is:
Marantz sr6200 av Reciever
JBL L 20t : Left/Right
Definitive Technology clr 1000 : Center
Bozak LS 200A : surrounds
M&K V-125 : sub
What can I do with the 1070 as I would imagine music would sound better than the sr6200..
Sent from my SM-G930V using Tapatalk
everettT
everettT
4 threads will not get your question answered quicker. If the unit has sentimental value, create a 2ch system for it. Otherwise there is no good reason to incorporate it into your theater system.
G
Gtmcmillanjr
Sorry for all the threads... I actually ran the preout of the av Reciever into the aux on the 1070 and ran the left and right to the 1070.... Sounds way better...
everettT
everettT
So your not using it as a preamp, but an amp. So more than likely your hearing a difference in spl . But if you like it , go for it
cpd
Don't get me wrong, I really like the nostalgia of vintage stereo equipment, but I think you are going about this wrong.
The amp section in your sr6200 is much more robust. You should be using it to drive your speakers.
Frankly, there is no need for the 1070 in your system, but if you want to incorporate it then hook your speakers back up to the sr6200 and run RCA cables from one of the Tape Out jacks on the 1070 to any line level input on the sr6200. Your 1070 will then function as a pre-amp and you can run sources into the 1070 or use its tuner and pass that signal on to the sr6200.
Again, there is really no need for the extra complication caused by adding the 1070, but the way you are running it now makes even less sense to me. If you had a turntable then I would set it up as I advise and connect the turntable to the 1070 as the sr6200 does not appear to have a phono input (at least from my quick goolge image search of the back panel).
G
Gtmcmillanjr
I'm not sure if I completely understand... I'm sorry I've never had a preamp or hooked 2 amps up together. The Marantz SR6200 only has pre outs , not pre ins... The Marantz 1070 is an integrated Amp and has pre outs and ins.... I just thought that music would sound better if I incorporated the 1070 into my system... Any advise?
slipperybidness
slipperybidness
Any of those inputs on the 6200 are "pre-ins"!
I agree with Post #2--Just get yourself a pair of speakers to run dedicated to the 1070. You may even look for a used pair of the same vintage.
G
Gtmcmillanjr
I'm sorry if this is a dumb question... But the Marantz SR6200 has pre outs and the ins are 7 channel ins... Are those the inputs your speaking of? Could you explain how I would run the Marantz 1070 as a pre amp to the Marantz SR6200?
slipperybidness
slipperybidness
Let's take a step back first. An AVR is basically a pre-amp and an amp in 1 box (plus a tuner). ANY input on an AVR is going to be a Pre-Amp Input! Unless you have some jumpers in the back that have are pre-amp out/Amp in, then we have a slightly different animal here.
Looking at the manual for the 6200, you have these as available pre-amp inputs:
Audio
Analog In
(CD, Tape, CDR/MD, VCR1,
DSS/VDR2, TV, DVD, AUX)
It doesn't seem that you have 7 Ch inputs on the 6200. It doesn't matter in the slightest because the 1070 is only 2 Channels anyway.
If you insist on hooking these up together, then I will let someone else make the explanation. I stick by my previous comment--Hooking these up together gains you nothing and adds complexity.
Go for another separate system on the 1070
