Can I use Logitech z-680 speakers with my Harden Karden AVR-135?
F
fire
I got a Harmon Kardon AVR135 reviever I would like to know if I can plug in the speakers from my logitech z-680s into the AVR135's banana plugs? The z-680 speaker wire is the standard wires.
Thanks
jcPanny
jcPanny
Speaker connections
Fire,
Those logitechs are powered PC type speakers. They must be connected to the included sub and can not be used seperately. The line level connections to the logitech sub would require pre-amp outputs from the receiver which your model does not have. Either stick with the PC as the source or save for a speaker upgrade.
For $100/pair BIC and Athena are good options. For a $200/pair, check out the X-LS speaker from av123.com.
Buckeyefan 1
Buckeyefan 1
As JCP says, keep the Logitech wired to the PC, and pick up some decent speakers for your Harpoon Karsten 135 receiver. :D (I had to laugh at the title)
BIC Venturi, Athena, and XL-S are all excellent bookshelves to use with the HK. Then you can save for a nice entry level HSU/SVS sub.
F
fire
Thanks for the info. Ill stick with them for now till I can get money for good home theater speakers.
