Can I use 2 Fmods to 1 sub?
I
Inertia
I ordered 2 20hz high pass Fmods.... What slope do they use? I was wondering if I plugged them both in to eachother if that would give me a steeper slope. I want to buy a mini DSP but I have no idea which one I need to buy... I will have 2 Jl audio W7s on the way and dont want to ruin them.
lsiberian
lsiberian
Honestly I'm unsure about the effectiveness of the Fmods. I'm a cheap skate, but I don't think they are good solution. You will need a revb minidsp especially if you are running dual subs. Don't worry about getting balanced for your amps because you shouldn't need it. The device is very small and you can run eq with one if you so choose. I recommend running an L-R4 filter on a ported sub at tuning for maximum driver safety.
