Can I still get HD if my sat box only has component input and TV only has HDMI?
johnnycoolxx
I just bought a new LCD HDTV and bought a satellite box.
The TV has 1 HDMI and 1 component connection for viewing HD, but I already have the component connection filled up by my XBox. (Yeah I know, not enough inputs. I have an Olevia 232V and otherwise it's great). So I just have that 1 HDMI for HD.
The satellite box only has 1 component and no HDMI. I have the sat box hooked up to my TV through the S-Video connection right now.
I want to be able to watch satellite TV in HD but I don't want to have to disconnect the component HD everytime I play XBox.
Is there anything I can do to fix that problem? I haven't seen a component to HDMI cable yet. Any suggestions?
Long time lurker, first time poster.
Thanks,
John
no. 5
no. 5
I highly doubt there will ever be a component to HDMI cable (HDMI is digital and component is analogue for one thing), but there are receivers and other devices that will up-convert component to HDMI.
Adam has a good suggestion, or if you have a receiver that has component video switching, you could use that.
majorloser
majorloser
Moderator
D-sub15 to RCA Component
I believe your set will accept the VGA as the second component port. From website, "2 Component + 2 R/L RCA Audio (VGA connector accepts as 2nd Component source)."
http://www.olevia.com/products/detail.aspx?pid=232v
If that's the case, all you need is a D-sub 15 VGA to RCA breakout cable to gain one more component input.
Something like this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023503&p_id=2409&seq=1&format=2&style=
Not sure if the VGA connection on the set is male or female. Either way it's just a cheap gender changer if the cable is wrong.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10416&cs_id=1041602&p_id=1191&seq=1&format=2&style=
EDIT: I bet you like my $3.00 suggestion?
Adam
Adam
That is a much better alternative to my suggestion if the TV can handle it. Cheaper, and it doesn't require manually switching the sources.
I also like no. 5's comments on having a receiver do it...I didn't even think of that. Great option if you have a receiver that can do it or are looking to get a new one.
