can I mount the ADP-390 on the wall? and what is the part number for the bracket to do so?
S smooth2222 Junior Audioholic Sep 27, 2009 #1 can I mount the ADP-390 on the wall? and what is the part number for the bracket to do so?
AVRat Audioholic Ninja Sep 28, 2009 #2 It would probably be better if you put it on a wall mounted shelf. That thing is rather large AND heavy.
JerryLove Audioholic Ninja Sep 28, 2009 #3 smooth2222 said: can I mount the ADP-390 on the wall? and what is the part number for the bracket to do so? Click to expand... Yes you can. There's even a safety strap (page 2 of the manual) if you do so. I would suggest reaching out to your dealer or paradigm (http://www.paradigm.com/en/paradigm/contact_us/) if you feel you need a bracket.
