Mixing is generally a bad idea, and in this particular case makes no sense to try to fill out just the low end. The PA150 has huge output 40Hz+; any sub that will have significant 20Hz-40Hz output suitable for a very large room will be a lot more expensive, and probably nearly as capable as the PA150 up higher. It would be better to skip the PA150 entirely, in that case. I would experiment with corner placement of PA150 to boost the low end.
That said...you might be able to get some improvement, but dual subs really don't work best by filling in holes - that's like using single subs for different frequency ranges.
