Can I make my Onkyo PR-SC5508 a 9.4?
E
ericruff
I have an Onkyo PR-SC5508 "AV Controller". It is set up to be a 9.2 system. All 9 speaker pre-outs are in use as well as the 2 subwoofers pre-outs. BTW, I call this setup the "Tribute To Phil Spector before-he-became-a-lunatic Wall of Sound."
Now I find I have access to 2 more passive subwoofers and an extra Parasound 2 channel amp that could power them. Of course, the problem is that the Onkyo only has pre-outs for Subs #1 and #2 and they are in use.
Well...maybe there are more sub pre-outs! The Onkyo also has outputs for two other "Zones"-- Zones 2 and 3. Each of those Zones has its own analog pre-out for a subwoofer. I was wondering if I could take the pre-outs from each of those and send it to my Parasound amp and send the signal on to these two extra passive subwoofers. Now I am up to 9.4 -- just have all the speakers and subs (all 3 Zones) in the same room! The Onkyo will, I believe, allow all Zones to be playing the same music and even allow the remote to control all Zone volumes. I would not (at least for now) be also using any other pre-outs for Zones 2 and 3, just the subwoofer outs --(would that hurt?) Anyone see any problems here with what I propose?
Cruise Missile
Cruise Missile
Just pick up a pair of RCA Y-cables. You can use those to split the sub-outs. It's the same as having two more outputs.
I would run both active subs on one and the passives on the other so that you can still use the level trims with the remote.
I believe I got mine from Rat-shack for way cheap. You can find them everywhere online also. Just make sure and get the "male to female" type and you'll be set!
Cruise Missile
Cruise Missile
Thinking further about this, it's fairly common to find an output on the plate amps on the back of powered subs. This is provided so you can daisy chain subs.
E
ericruff
Does the "signal" from the splitter get "weakened" and end up as half as strong as if I had not split it?
markw
In theory, yes, but in the real world it's not an issue. That's what gain controls are for.
