Hi.
I'm going from bi-wired B&W's to single-wirable Dynaudios.
I will have extra runs of the QED Silver Aniversary, and I'd like if possible to use these to make the cable run longer so that I can get the cable under the carpet and out or the air(at the moment the bi-wired are to short and travel through the air to reach the speakers)
What I'm wondering is can I simply twist to runs of cable together to get one run. I know it will work, but I'm wondering if there will be any noticable or theoretical loss of signal quality? (Obviously at the join the twisted pattern of the cable will be broken, and for and inch or so there would be no plastic jacket insulating the cables)
Many thanks
Bevan
