Can I hook up a dbx1031 equalizer to a yamaha 5660 receiver?
Danparra
Can I hook up a dbx2031 equalizer to a yamaha5660 receiver?
everettT
everettT
No. You need to add external amplification.
You could, but it's not stereo. It also uses Low Impedance connections, so you would need to deal with that, too. Plus, the Yamaha doesn't have a tape loop and a way to use this.
everettT
everettT
For the reasons you mentioned. :). Unless he puts it behind one source. I'm assu6he wants an eq because he wants to play with it. Just wanted to put it to bed as EQing by ear isnt worth the trouble.
TechHDS
I had a BBE, DBX maximizer back in the day. Absolutely loved it !
Mike
So you'd need at least two DBX 2031's on the pre-outs before external amps just to eq stereo....sounds expensive.
BoredSysAdmin
BoredSysAdmin
Good news: Your Yamaha 5660 already has built-in 5 channels GEQ
Bad news: It's only for the center speaker :(
When I googled that model, I found a used one for $88.
Still....a miniDSP would still be my choice :)
I didn't know the MiniDSP had that many bands.
Regardless, this isn't made for a home stereo and the receiver wasn't designed to use one anyway.
Johnny2Bad
Johnny2Bad
What problem are trying to solve with a multi-band graphic EQ?
Andrein
I think my minidsp has 10 bands across 8 channels. Still cant find time to set it up properly.
So, MiniDSP doesn't- its bands are spaced an octave apart and the dbx has 1/3 octave spacing. Not equal, in that regard but the dbx is ONLY an equalizer.
From the minidsp page "Graphic equalizer: This bank of filters will increase or decrease the signal at a specific frequency. Depending of the MiniDSP firmware configuration, you may have 31 bands (also called 1/3 octave) or 15 bands (2/3 octave) available. By boosting/dampening the signal at certain frequencies, speaker equalization is the most common tool for system tuning"
