MakeYouTap
can i turn my down fireing sub on it side without damage or poor sound quality ??
Is this a problem of placement? It shouldn't make a big difference sound wise. It depends on the construction, or quality of that construction, but it shouldn't be a problem.
MakeYouTap
im doing a final placement check before i run my wires through the floor, if i can put my right side sub on its side i can put it under a corner table .
ParadigmDawg
ParadigmDawg
I have used my sub turned about every way I could think of.
