can anyone give advice on an old bike?
chris357
chris357
ok, the cool news!! I just got for FREE!!!! yes FREE!!! a 1986 honda shadow vt700c from a guy a few houses down.. he had to get rid of it and it doesnt start and they were closing on his house and he had to get it out of his garage ASAP.. I offered to buy it a few months ago but anyway it was FREEEEEEEE :)
however the bad...
I new the battery was dead and I wasnt sure about the gas it had been a year or more since he had ridden it. I was tinkering(yes very dangerous since I have no clue what I'm doing) and I pulled the battery and connected a jumper box and tried to start it.. it cranked but didnt turn over.. ok I didnt think it would but wanted to try.
so I got a new battery and a charger added the stuff and hooked up the charger.. it is a cool little automaitc one. it seemed really low on gas so I added some gas and hooked up the new battery and got lights and stuff.. but when I hit the started it does nothing.. no turn over at all.
yes its in nuetral, I;ve tried it kick stand up and down choke off at least I think its off.. but nothign is happening.. what can I try
I did and you may laugh at me again not a mechanic but I took the air filter off and sprayed some gum out inside and thats it.
any advice would be great!!!!
thank you
and heres a pic :)
jeffsg4mac
jeffsg4mac
Republican Poster Boy
Not sure about that model but some bikes you do have to hold the clutch in as well to start it. Other than that I would take to a good bike mechanic.
chris357
chris357
i've tried a couple different ways.. clutch no clutch kickstand, nothing.. i'm trying to avoid the cost of a mechanic however I know I'm being cheap(seeing as the bike was free) but money is tight..
caupina
It seems like an electrical issue. When you put the new battery, did the lights turn on, ie: headlight, warning lights, any light at all?????. Check the spark plugs, and the starter. It seems to me that no electrical current gets to the starter. Just my thoughts.
chris357
chris357
everything lights up.. just nothing happens when I push the starter
What do you mean by it cranked but did not turn over? That makes no sense to me, please explain. Never connect a battery booster charger, and try and start a modern engine with the battery out. It can do a lot of damage.
In order to help you, I need a precise definition of what cranked but did not turn over means. To me they are one and the same thing.
If you don't know what you are doing you can do expensive damage quickly on modern engines.
If the starter does not turn at all, then the problem could be an ignition interlock you have not found, or a broken interlock.
It could be the ignition switch, a bad connection to the starter solenoid, a bad solenoid, a bad starter motor. Other possibilities include a bad battery ground, corroded battery terminals, and a bad starter relay if it has one.
You need to get a test light and obtain data. You will never solve this making stabs in the dark, in fact you will do damage if you haven't already.
You need a service manual and good tools to begin.
chris357
chris357
good point
you know, I was googling shadow owner forums and not googling the question.. again this is why I come here :)
and this is why I thought that a motorcycle forum would be a great place.. but the one I found I have not even gotten a response yet..
chris357
chris357
ok yeah that didnt make sense did it.. it was cranking and turning over but not starting. like it was out of gas.. and yes I looked for a fuel tank selector and it appears this model does not have one.. I thought bad gas but it really didnt have much gas in it..
and yes I am coming to the conclusion that I have no clue what i'm doing and the simple things liek it just needs a new battery is not working..
its a nice bike and I'm pretty sure its worth fixing so i'm going to stop being cheap and dumb and get a real mechanic on it.. :)
then I can get back on track for building my subs :)
Sheep
Sheep
good point
I love how you saw the humour in my post, and it helped you, but some coward thought it wasn't helpful.
Adding to the list.
SheepStar
CraigV
CraigV
Is there a manual gas valve that needs to be flipped? Can you get to the carb & spray it with carb cleaner?
Change out the spark plug (and cable if it’s not too difficult) change the oil and get rid of any old gas in the thing.
Rickster71
Rickster71
If the original owner is still around ask him a few questions.
1. Did he use a fuel stabilizer?
2. When was the last time he had it running?
At this stage, knowing if he used a fuel stabilizer http://www.goldeagle.com/brands/stabil/default.aspx is the most important thing.
Fuel deteriorates, and the longer it was stored, the more gummed and varnished the fuel system will be.
Starting it with bad fuel will suck the varnish and sludge into the carburetor.
Unfortunately, this isn't a job for someone that's inexperienced.
In that case your problem is either ignition or fuel. Ignition problems are more common than fuel problems.
I have found your bike has solid state ignition, and it is distributorless.
It will be the same type of system as on outboard motors which, living where I do, I'm very familiar with.
First do this. Get a can of carb cleaner or ether, and squirt it down the carb air intake, and turn the engine over as you squirt it. The engine should fire if there is spark. You need to remove the air filter hose and squirt directly into the choke tube.
If the engine does not fire, then you almost certainly have ignition trouble.
Now this is how these systems work. Inside the fly wheel, there is a charge magnet and charge coil for each cylinder, and a sensor coil and sensor magnet of each cylinder. The charge magnet and coil charge a cap in the ignition pack. The sensor magnets and coils destabilize a silicon controlled rectifier, in the ignition pack and discharges the capacitor for that cylinder into the primary of the ignition coil for that cylinder, and a very high voltage, thousands of volts, is sent to the sparking plug from the secondary coil to the sparking plug for that cylinder and you have spark.
Now these systems are fragile when you work on them. If your ignition module was not blown before, it almost certainly is now, as you cranked it without the battery in. Booster charger produce and unsmoothed rough DC, and the battery acts as a giant smoothing capacitor. The rough DC from booster is instant death to those ignition modules.
The other thing that blows them is removing a plug to see if you have spark. If the plug fails to ground for a split second the module blows. Also I have seen cases were the ground from the module has gone bad. This blows the module and the one you replace it with, if the ground issue is not corrected.
You have to check the spark with an ignition tester. They are quite cheap.
If there is no spark, then you need to have testers to check that the charge coil are working and the sensor coils. If there is no output to the ignition coil pack, then replace the ignition module. With the age of your bike, the caps in the ignition module are almost certainly no good. You have almost certainly totaled your module anyway.
Now I have found out that the coil packs on those bikes give a lot of trouble, and so do the ignition switches. You might be very lucky and just have a bad ignition switch. You can test this with a test light and make sure you have 12 volts to the ignition module.
The bad news is that production runs on bikes and outboard motors are small compared to cars, and ignition parts much more costly. An ignition module for a small fishing motor is a round $200. For a big powerful six cylinder outboard about $400. The coil packs usually run even higher.
From what I have found out, it is quite probable that your bike needs an ignition module and coil pack. With labor that will probably run to about $750 with labor. If you are unlucky enough to have cracked coils in the flywheel, its going to go over a $1000.
If the bike fires when you squirt in ether or carb cleaner, then you have fuel problems.
First remove the fuel hose from the carb. Then crank the engine and see if a squirt of fuel comes out of the hose. If it does not disconnect at the fuel filter. If no gas then replace the fuel pump. If there is gas replace the fuel filter.
If there is gas at the carb, get a set of carb gaskets and a a carb kit. remove the carb, clean it and rebuild it.
If the problem is fuel, or the ignition switch you very likely will be successful in getting the bike running yourself, if you are careful.
With you level of expertize, I doubt you can repair the ignition system, but if you get the right equipment use you head and take it steady you well could.
I have had one further thought. It is possible that on that bike the solid state ignition module os part of the coil pack. That may be the reason, there are so many reports of failure. If the bike fails to fire squirting carb cleaner down the choke tube, go and buy an ignition tester. Make sure you ground it well to the engine, and then connect the spark plug leads to the tester. Crank the engine and see if a healthy blue spark jumps the point electrodes.
If there is no spark, I would replace the ignition module, and I have the feeling yours is module and coils in one package. With what you did that unit will be toast if it wasn't before. Sensor and charge coil problems are quite unusual in my experience.
If you install a new unit, take care not to switch any wires and check grounds for continuity carefully. Of course check for ignition switch problems first.
Too bad you don't live near hear, we would have the diagnosis in short order.
chris357
chris357
Thanks TLS guy thats alot of research you did for me.. thank you. it is looking like I may be out of my scope. I am going to sit tight and wait until i get the manual the previous onwer says he has.. then at least there will be pictures and diagrames i might be able to follow.
I have recently been doing more stuff on my car (very basic stuf, oil changes, o2 sensors, and stuff) and since my investment in this bike is nil it might be a low risk way of learning how to do some stuff..
I think the most important thing now is diagnosing the problem and I will need to wait for another paycheck to get the tools I might need.. I will also check around if friends of friends have any.
as for some of the other questions.. there is no switch for fuel that would have been to easy :)
chris357
chris357
Adding to the list.
SheepStar
I laughed my *** off at myself for not thinking of it. Its also funny to me since its something that I woudl do as well :D
sawzalot
sawzalot
Congrats on your new, free toy.It looks like you got plenty of excellent advice, especially from TLS guy. I would suggest one more thing since you are going to sit tight for now, the fuel tank is prolly the easiest part to remove next to the mirrors, I would seriously consider removing the tank and flushing it out with a 3.99 can of fuel stabilizer empty it out and add fresh gasoline after you re-install the tank, as mentioned by op'ers the gummied sludge will totally wreak havoc on the carbs and magnify your problems ten-fold, just a thought.
A service manual is indispensable. It saves an awful lot of money if you can do your own service work. Also if you ever want to know the least likely thing to be causing the problem you are having with your vehicle, ask a service manager! It will be the top of his or or her list.
chris357
chris357
at this point I'm going to stop doing things until I get teh manual. i dont think a few more weeks of sitting is going to make the gas any worse. I'm pretty sure he didnt add any stabil to the gas tank.. again this is why its free.. it cant be totally easy I have to work a little to appreciate it :)
even if it costs me in the end up to 500 to fix i think I'm in.. it is worth probably 1500 or more so i will see..
what I'm finding is that there is not a simple thing I'm overlooking here.. its looking more complicated than just an oversite.
I got this just as i was about to start cutting wood for my kappa subs build that I just finished getting all the parts I need for.. and this was a distraction from that.. so i think I will focus on that for now :)
thank you and i will keep you all post to the progress :)
mperfct
mperfct
Dang, I thought this was going to be a real bike thread, not a motorcycle thread (I like those too, though).
chris357
chris357
ok I learned a couple things.. first .. I have a petcock (the manual fuel switch)
i giggle everytime a say that.. yes I'm an imature 40 year old.
next I got her running badly but running..
has to be at full choke and will stall if giving gas but will start and run at idle
wooo hooo
I didnt screw to much up with my poking and dumb floundering around.
