I am semi new to all of this, but I am definitely far down the rabbit hole and enjoying the process and learning!
Anyways, I am looking to integrating and using multiple sub-woofers and had a few questions. Specifically about REW, equalizer APO vs minidsp and multi sub optimizer. My setup is 100% for listening to music and I am using my computer as the only source of music.
The setup is Computer -> hdmi output -> receiver -> 2.2 or 2.3 setup.
I have a single sub output from my receiver so I was wondering do I need a mini dsp to equalize numerous subs or can I do other ingenious work arounds just using Equalizer APO. I was wondering can I use the unused central and rear outputs of the 5.1 outputs to each go directly control each sub?
Can Equalizer APO do that (send the sub signal to various other channels)?
If so, any good guides online (as I have searched everywhere and not seen someone comment how to use equalizer apo to re direct the sub output to various other channels and then equalize them independently)?
Any thoughts about the current setup and ways to optimize it?
If this is not a possibility, are there any good ways to optimize and integrate multi subs without buying a minidsp?
Basically I am asking.... Do I need a mini dsp (or equivalent) for multiple subs or can I just use equalizer APO?
Thanks so much for any info! As I was going to get the umik-1 this week and making sure I don't need to order a minidsp also.
Thanks!
