There are two separate issues here. One is whether or not the av receiver you picked out will work well with the PSB imagine speakers. I have and love the PSB imagine b bookshelf speakers but they are a tough load for a lot of receivers; you will need something that is 4 ohm stable. Plus all you want is something to play classical music with, right?
Thanks bikemig,I forgot to mention that currently I have a 5.1 setup ,(recently upgraded to 7.1) of which 5 of the speakers plus the sub is from psb, for listening music I use the PSB Imagine T2, not the bookshelf speakers, I am also an avid movie buff ,so the speakers are used for multipurpose.( I know it's not an ideal setup for classical music) I don't have golden ears ,since my room size is medium, I am planning to get the onkyo tx-nr 626 receiver(currently I am using onkyo tx-nr 809) which will serve both my purpose,watching movies and playing my digital files through dac magic plus,but if my av receiver is already equipped with equal or better dac,is it necessary for me to use the ca dac magic plus? This is only for my digital files.
For classical cd's I have a cayine valve amp & marantz k-lite pearl CD player.
Thanks to both of you for your kind advice.
